filtering traffic with irule
Hello, I’m trying to create an irule that will only allow traffic to the VIP if it matches a specific header, all other traffic should be dropped. Is there an easy way to accomplish this?
You can use an Local Traffic policy to do this:
Or a simple iRule:
    if {!([HTTP::header exists "my-header-name"])} {
        reject
Even if you request a Drop, I would suggest to send a 403 response page instead!
Take the lee’s Answer and replace reject with
HTTP::respond 403 content {put here the html content of your blocking page}
