Hey all,
I’m looking to modify and existing IRule that looks at UDP payload in a request, and then drops certain requests, but allows others. I want to expand it to filter and log certain requests, and process the others via a class file instead of an IF, ELSEIF, ELSE string of rules. Let me know if you see anything out of place with the rule below.
class log_sso {
class reject_sso {
anonymous
Enter your SSO ID here
when CLIENT_DATA {
set log_sso [matchclass [UDP::payload] contains $::log_sso]
set reject_sso [matchclass [UDP::payload] contains $::reject_sso]
if { -1 != $log_sso } {
set sso [lindex $::log_sso [expr $log_sso - 1]]
set client_ip [IP::client_addr]
set payload [UDP::payload]
log local0. “User $sso connected via AP with IP address $client_ip. payload = $payload”
} elseif { -1 != $reject_sso } {
discard
pool wlauth-servers
Thanks!!
