Hi All,
I have special requirement for the ASM to check on “xyz” parameter and only grand access to the web server if the value of the parameter is mapmap or xy_get_data.
I created the parameter under parameters and linked it to the specific URL, enable blocking on the blocking page. However, i am not able to know where i can specify the values mapmap or xy_get_data.
Thanks in advance.
Regards
Hussein
Hello Hussein,
i’m not sure ASM is really able to do that. what you could implement :
- a LTM policy to allow or reject based on the presence of this parameter
- an irule doing the same with the possibility to trigger an asm violation in this case
- a signature in ASM (but i’m not sure if with can implement negative matching)
If your parameter is only allowed to have two permitted values create it as a static parameter type in your policy and add your allowed values as static values. Make sure “Allow Empty Value” is un-ticked. Make sure your policy is blocking on violation: “Illegal static parameter value” .
That’s it!
