Filter Specific ajax requests under a URL and grant access accordingly
Hi All,
I have special requirement for the ASM to check on “xyz” parameter and only grand access to the web server if the value of the parameter is mapmap or xy_get_data.
I created the parameter under parameters and linked it to the specific URL, enable blocking on the blocking page. However, i am not able to know where i can specify the values mapmap or xy_get_data.
Thanks in advance.
Regards
Hussein
If you are interested in a general block unless the parameter matches one of these two strings, I would suggest looking at your Local Traffic Policy. You can configure a forwarding rule that looks for one of these two strings and if it doesn’t find it discards the request. You can read about local traffic policies here: 404 Page not found | BIG-IP Documentation
This is probably the easiest way to accomplish what you are trying to accomplish.
