Fan Speed on BigIP 2000 device pls help!
Hi! All
Can someone help fix high fan and noise ?
Sys BigIP 2000 with 11.6.5.3-0.0.2
Two same systems have same problems
Fan always work at maximum speed at 12K RPM (((( with no overheat and low CPU and etc temps …
Chassis Temperature Status
Index Lo Limit(C) Temp(degC) Hi Limit(C) Location
1 0 23 43 Main board inlet IC temperature
2 0 25 59 Main board outlet IC temperatur
3 0 32 65 Power supply #1 meas. inlet tem
4 0 34 59 Main board near power supplies
CPU Status
Index Temp(degC) Fan Speed(rpm)
1 35 11806
Hardware Version Information
Name lop
Type pic
Model F5
Parameters -- --
Boot loader version 1.04
Firmware version 4.08
Chassis Fan Status
Index Status Low Limit(rpm) Fan Speed(rpm)
1 up 1000 12000
2 up 1000 11806
3 up 1000 12200
4 up 1000 12000
@Den-78 I would open a ticket with F5 TAC for this issue.
Hi  @Den-78  ,
As  @Den-78  mentioned, you have to open a support case in the web portal https://my.f5.com/manage/s/.
Just take in mind that version 11.6 is not supported by F5
So if they request a qkview they going to decline your case and is necessary to upgrade your F5 system, you can find info of how to upgrade your system:
Hope it´s works.
Hi!  Sebastiansierra
I don’t think its hardware problems or os bug, fresh install 11.6.5.3-0.0.2 (last for contract) and in test 17.1 )) = same results, all fan at 12K RPM … (((( In EDU = all hardware test pass, and fan report as in os = 12K …
I think its “bug” in AOM firmware, now its last 4.08 as i can see
2 same systems have this problem
May be some way to control fan ?
