Failover state
If I reboot the standby device (and do nothing to the active device), after the device is rebooted would it remain the standby device? Or would a failover occur?
It really depends on HA configuration. I recommend you use the
Force Offline
state, this will ensure your unit will not process any traffic so you will not have to be concerned about possible impact due to reboot.
