Failover just with HA interface
Actually playing with HA environment with 2 LTM, when configuring Failover, by default HA & Management address are selected and it Works correctly (active / passive), but when I put only HA (without management in unicast failover section) both F5 shows state ACTIVE / ACTIVE and each one appears to other as Offline.
It’s necessary always include MGMT address? I’m conecting directly the 2 nodes without passing through a Switch, that’s correct? or it’s imperative interconect through switch?
Many thanks!!
Active/Active status is probably caused by Port lockdown ‘None’ configuration on your HA VLAN/SelfIP which is the default setting. Set it to ‘default’, and try again. Specifying the management interface in network failover configuration is not necessary at all.
Thank you! Great!
Thank you! Great!
