Greetings,
I currently have an iRule that will failover an http request to a secondary “failover” pool if there are no available members in the current pool. The failover pool simply contains a single vip address that is hosted on a different load balancer (that happens to be serving the same content).
I’m looking for a way to eliminate the need for a secondary failover pool. The pool is necessary in the current iRule design because I am using the “pool” command. However, within the iRule I can determine (or hardcode) the failover destination. I could not find an iRule command that will let me simply forward the request to a given ip/port, without an intermediary pool. Note that I’m not looking for “redirect”, I want the traffic to flow through the original LB, through the original connection.
