We have a new pair of F5 4000s in our data center and I am attempting to configure them as an HA pair. I have looked through the documentation but am unable to find how/where to configure this cable as the HA failover. Do I just create a dummy VLAN and if so which interface would it need to be assigned to?
TMSH currently shows this. I know 1.2 is my external VLAN, 1.1 internal and 1.3 another internal VLAN.
Net::Interface Name Status Bits Bits Pkts Pkts Drops Errs Media
In Out In Out
1.1 up 10.8G 2.5M 6.9M 3.9K 0 0 1000T-FD 1.2 up 6.9G 28.6M 7.8M 54.8K 0 0 1000T-FD 1.3 up 109.0M 12.3K 50.5K 20 0 0 1000T-FD 1.4 down 0 0 0 0 0 0 none 1.5 down 0 0 0 0 0 0 none 1.6 down 0 0 0 0 0 0 none 1.7 down 0 0 0 0 0 0 none 1.8 down 0 0 0 0 0 0 none 2.1 miss 0 0 0 0 0 0 none 2.2 miss 0 0 0 0 0 0 none mgmt up 49.2G 1.6G 44.7M 688.7K 0 0 1000T-FD
The failover cable goes into the failover port. It’s a dedicated port to interconnect two BIG-IP. Failover cable is not mandatory to setup HA, but can trigger faster failover. So it can be used with a Network Failover configuration. My recommendation is to create a LACP trunk of 2 interfaces on each of your BIG-IPs. Create a HA VLAN untagged to this trunk on both devices Create a Self IP with Port Lockdown Allow Default on the HA VLAN on both devices (in same /30 network or bigger). Use these IP to configure ConfigSync, Network Failover and Network Mirroring if you need mirror SNAT, VS connections and/or persistence records. Salim
Thanks, I understand how I can create the HA VLAN, but still unclear about the failover cable. Just to be clear, it does not have an actual interface assignment on the F5, right?
Correct. It used to be a DB9 port but it’s RJ45 now on new models, but it doesn’t appear as a data interface. You can do everything without failover cable as long as network failover is properly configured. Adding failover cable in conjuction to network failover will give you faster failover detections on your Standby unit so it can go Active quicker. Of course it is limited to 2 devices and they need to be close to each other due to cable length limitations. Salim
