I am trying to do something that I thought would be fairly straight forward, but I cannot figure out how to do it.
I have a pool of 2 nodes which serve out an application. They cannot run in active/active mode, so they run primary/backup. Using the priority within the pool, I have things setup so that when the primary goes down, things properly start to go to the backup. The problem is that when the primary comes backup, it again starts to receive the reqeusts. I need the newly assigned (used to be backup) server to remain as the active one. I thought there would be a way using LB_STATUS within an iRule to change the priory of the members of the pool, but I cannot seem to find a way to do that. Does anyone know if there is a way within an iRule to change the priority of pool members?
