F5 WOM Question
From GUI " WAN Optimization ›› Local Endpoint ›› Properties"
The option SNAT , has 3 possibilities in drop down menu : None , Local & Remote .
i chacked the documentation & found the explanation fro each & it is below , i understood it but i need to know why it is mentioned that :" Use Remote when an appliance that uses NAT is located between the WAN Optimization endpoints "
below is explanation from Documentation :
SNAT :
Specifies the address the system uses as the source IP address of the
TCP connection on incoming traffic from the WAN Optimization Module to
the server.
*None: Indicates that the system uses the original connecting client IP
address.
*Local: Indicates that the system uses the endpoint IP address closest to
the destination.
Use this setting to make sure the return route also goes
through the BIG-IP system, so that both sides of the connection can be
optimized.
*Remote: Indicates that the system uses the source IP address of the
incoming iSession connection. Use this setting when an appliance that
uses NAT is located between the WAN Optimization endpoints. >>>>>>>>> Why is that ?
Hi
