We have customers connecting to a web server A.
The web server is actually made of 2 physical machines A1 & B1 which are load balanced
machines A1 & A2 are accessing a single oracle database through jdbc (dbnode1).
This database node is not clustered. It’s simply using a physical standby database.
Now this is a platform and we have N of these platforms.
What we would like to do is to reduce the number of web servers so that, for example we would have :
Webserver A (A1 & B1) connecting to dbnode 1, dbnode 2, dbnode 3 …
Of course this would mean the ability to be able to identify to which database node a sql query must be redirected.
As far as we are concerned , the only way for us would be to put a commentary in the SQL statement, identifying the database node we want to connect to and having a proxy SQL receiving these Statements from A1 & B1, being able to trap the comment and establish to connection to the correct database node.
Is this something which can be achieved with F5 ?
Olivier
Hi Olivier,
An Oracle database proxy as you’ve described is on our radar here at F5, especially for the primary use case of directing traffic appropriately to read-only vs. write database nodes. However, in order to peek into the stream and see the SQL, we’ll have to reverse engineer Oracle’s proprietary SQL*Net software, which is no small undertaking. Hopefully we’ll be able to support this requirement someday, but it is not currently available or scheduled for a near-term release.
Best regards,
Holly Willey
F5 Product Management Engineer
http://www.orafaq.com/wiki/SQL\*Net
Hi Bernhard, one additional thought. Is it possible to distinguish the target database by looking at the HTTP request ( GET or POST ) ? If so, the F5 could use an iRule to read the HTTP request, something in the URL, a cookie, or an HTTP header, and direct that HTTP request to a specific webserver, which is attached to a specific database ? This is more along the lines of inspecting/controlling traffic at the HTTP layer instead of the DB layer, but it has been done by other customers and is pretty easy with iRules. Just a thought…
-Chris.
