F5 Websense Content Gateway Assistant
Problem this snippet solves:
update to Websense content gateway assistant. This same file was somehow removed from dev central. Template create by Jonathan Knepher of Websense/Forcepoint.
How to use this snippet:
import as an IApp template
Code :
74147
Tested this on version:
11.6
This template breaks HTTPS reporting as client IP address. V1 HTTPS traffic reports correctly V3 does not. Trying to find the differences now.
EDIT: Found it. It does not set the HTTP profile to insert X-Forwarded-For header on HTTPS LB Virtual Server
