f5 vmware lab implementation
Hi i have to implement a lab tapology in VWMARE using F5 LTM Ve11
i have made Ext-Vlan -for outgoing traffic Int-Vlan for local taffic and assigned IP also my servers are able to reach F5 F5 is not able to reach any server .
refer to exibhit
How have you proven no connectivity to the servers ? Are the servers also hosted on VMWare ? If they are , and all on the same /16 subnet (My word that’s a big address space ;)) THhen the interconnectivity should be sorted by the VSwitch.
Are you SNATing on the F5 ? What are the servers Default Gateways ?
Make sure you have SNAT AutoMap enabled on the Virtual Server
