F5 Vlan enquiry
I came across a config in the F5 as below:
Active F5:
self 192.168.10.2 { netmask 255.255.255.0 vlan Server_VLAN allow default
vlan Server_VLAN { tag 4094
self 192.168.10.1 { netmask 255.255.255.0 unit 1 floating enable vlan Server_VLAN allow default
Standby F5
self 192.168.10.3 { netmask 255.255.255.0 vlan Server_VLAN allow default
I noticed there are no port associated with the tag 4094. Can we consider this as functional IP & Vlan? Thanks.
rgds.
The vlan definition (object) should have an interface associated, for it to be functional.
E.g. vlan Server_VLAN { tag 4094 interfaces 1.2}
Is this on a vCMP guest? The config on the Guests does not include the interfaces - they are defined on the VIPRION Host instead (in v11.4.1 anyway).
