F5 Visual Studio Code extension not listing Big IP device partitions for 17.5.1.5 QKViews
As a general practice, after I upload qkviews to iHealth I then copy them to my visual studio code workspace. In the past, pulling them up using the BIG-IP extension, it would show all the source conf files and partions. For all 17.5.1.5 qkviews I’ve generated this past weekend, none of them have the source/partition data.
Is this a bug, did F5 change something in the way this new build processes qkviews? The extension is pretty much worthless without it. To be sure it’s limited to 17.5, I pulled up several 17.1.3.1 QKViews and the partitions/sources loaded fine.
Hello @woody_46
Thanks for posting the issue your having with iHealth. I have done some digging and reaching out, it doesn’t appear there are any changes that would impact this. I would suggest in this instance to create a support case to have it reviewed by an engineer for a protentional bug.
-Melissa
