F5 viprion 2250 upgrade procedure
What is the procedure to upgrade the hotfix on f5 viprion 2250.currently it is having 12.1.2 version running.does the hotfix needs to be applied both to vcmp guest and chassis
there are some views on it here: DevCentral - An F5 Technical Community
and here: http://www.fransvandokkumburg.com/f5-how-to-upgrade-a-vcmp-guest/
the advise is first host then guests. there also is a limit between the difference in versions.
Upgrade steps are similar for guests, host and non vcmp boxes. One thing is different. License can be reactivated on host only and guest inherit the license.
Upgrade steps can be found on askf5.com
