Hello All :
vCMP are 6 guests :
If host is 14.1.2 versions ,guest 1、2、3 is 14.1.2 versions,but guest 4、5、6 is 14.1.2.3 versions。
what is the affect? or no affect?
thanks all
Hello All :
vCMP are 6 guests :
thanks all
host and guest can be different major versions with no issues - it is likely there will be no difference between minor versions
thanks you ![]()
