F5 utilization
Hi Experts, I have a requirement to onboard new applications to F5. Before that I need to check if capacity also needs to be increased. I have a 1G perpetual ASM+LTM license
what all parameters should be considered to check current capacity utilization
Does increasing CPU and RAM has any implication on license type or it can be increased to any value
Hi D99,
Increase of RAM has no license implications. Increase of CPU depends on the exact license you own / subscribed (Good/Better/Best bundles)
Overview of BIG-IP VE license and throughput limits (f5.com)
CPU, RAM and throughput rates are the most effective counters to estimate spare capacity.
Cheers, Kai
Thank you Kai. Much appreciated
