F5 Uptime GUI
Is there any way to get F5 uptime through GUI.I know we can check it through CLI but what If I wana see through GUI.
Hi Korai,
from my knowledge it is not possible. you can make the check only by using the CLI
tmsh run /util bash -c uptime
Regards
Korai,
There is no such option, all you can do is - generate a qkview and view in the Ihealth if you would like a GUI feel.
