Hi all,
Trying to upgrade f5 big-ip 6400 from version 9.0.5 to a supported version. After running command “local-install” I get the following warning
WARNING: filesystem integrity test failed.
Product images will be irrevocably lostif this installation session continues!
A startup filesystem check may correct this problem; please reboot and try again.
The following product image locations are affected:
HD1.1
HD1.2
Continue with installation?
I click on No here. I have checked f5’s website and rebooted appliance to no avail. I’ve also booted up into single user mode and run a manual file check (f5 SOL6440). This also hasn’t resolved it. I still get the above warning.
Result of fsck -yaf is:
fsck -yaf
fsck 1.32 (09-Nov-2002)
/: 28228/92736 files (0.9% non-contiguous), 306243/370944 blocks
/shared: 1574/525312 files (2.0% non-contiguous), 159451/1048576 blocks
/config: 117/16560 files (7.7% non-contiguous), 6957/66023 blocks
/var: 284/17568 files (12.0% non-contiguous), 56152/69991 blocks
Thanks for any input on this.
N
