F5 Upgrade path 11.4.1 to 11.6.1
Hello I tried to search for upgrade path 11.4.1 to 11.6.1 but found none. Can you help us know what will be our upgrade path from 11.4.1 to 11.6.1 Build 2.0.338
Thanks!
is it this one?
K13845: Overview of supported BIG-IP upgrade paths and an upgrade planning reference
You can upgrade directly 11.4.1 to 11.6.1
Thank you everyone! :smiley:
According to this article, the recommended 11.6.x version is 11.6.2
F5 won’t release any hot fixes for versions 11.6.0 and 11.6.1 as 11.6.2 is released.
