F5 Upgrade and ASM Signature
Hello,
Simple and quick question.
I have an F5 running version 11.x. Module ASM is installed and last signature update is from 04/2016.
If I upgrade my F5 to version 12.x, what is going to be the behavior of the ASM signatures ? Will it remain as of 04/2016 ? Or does the F5 upgrade comes with a forced ASM signature updated too ?
Each tmos version has its base version of attack signatures. So when you upgrade you will need to upgrade your signatures. If you need a specific version of signatures you should be able to download them from f5 downloads.
N
