F5 Trunk port is connected to Cisco Switch Access Port
Any issues if F5 Trunk port is connected to Cisco Switch configured as Access Port? Will there be any loop formed?
If in case cable is wrongly patched as below.
  1. F51 Trunk port1 to F52 Trunk port12. F51 Trunk port2 to Cisco Access port → Any issues or STP loop?
The two ports above are members of the same VLAN.
Thanks.
Frist:
The term “trunk” in the F5 world means something different than “trunk” in Cisco world.
In the F5 world (and most non-Cisco switches) a trunk is the same thing as Cicso Ethernet Channel. That is two or more physical interfaces that are treated logically as a single interface.
Second:
Does F52 have a connection to any other switches in your network? If so, then it is possible that you could have a loop.
Hi Giltjr,
There is one more management interface connected to different VLan in the same switch.
I have attached the diagram of the scenario. Just in case the Trunk Port2 is connected to the Access port instead of the Data port as shown in diagram. The trunk ports are for HA links between the two F5’s.
Thanks!
Hi Giltjr,
Here’s the summary of network connections from above updated diagram.
1.F51 Trunk port1 to F52 Trunk port1
2.F51 Trunk port2 to SW1 Access port → Any issues or STP loop?
3.F52 Trunk port2 to SW2 Access port → Any issues or STP loop?
4.F51 Mgt Port to SW1 Access port
5.F52 Mgt Port to SW2 Access port
Will be any loop if cables were connected wrongly as above?
Thanks!
Hi Giltjr, The connections looks ok and what I can predict from above diagram is that the two switches are stacked. Is it? If yes then just as part of the design and if you have ports avaliable on your F5 box select another port lets say 3 on each box for the one connecting to the switches access port and connect F51 to SW2 and F52 to SW1. As the secondary box does not process any traffic there should be no looping unless you are keeping both the boxes as Active Active only then the looping has to be investigated.
Regards,
Hi Techgeeg,
Thanks for your reply. I have created a new diagram with the intended setup and a scenario if in case the network cable is patch wrongly from switch port to trunk ports configured as LACP in F5.
Will there be any loop if one of the trunk port member for both F51 and F52 are connected to switch1 and Switch2. The trunk ports are member of single VLAN as untagged interface. The redundant F5 are configured as active / standby.
Thanks a lot!
Scenario when one of the F51 and F52 trunk ports are connected to Cisco Switch Access port.
2.F51 Trunk port2 to SW1 Access port → Wrongly patched cable. Any issues or STP loop?
3.F52 Trunk port2 to SW2 Access port → Wrongly patched cable. Any issues or STP loop?
4.F51 data port to F52 dataport → Wrongly patched cable
More details about the setup from above diagram.
■ Switch 1 and Switch 2 are not stacked.
■ F51 and F52 trunk ports are configured as LACP (Active mode)
Thanks.
The wrong cabling (From the diagram above) won’t cause issues because you’re running LACP on the F5 trunk (Lets call it a port-channel :slight_smile: ).
The LACP signalling ensures that BOTH ends of all the links in the channel connect in a single port-channel. If any of the links are NOT configured in the port-channel, then then will be shutdown by the endpoint detecting the error.
So, as long as LACP signalling is used, you shouldn’t get any issues. (This assumes you’re not bridging traffic across the BigIP’s interfaces of course).
H
Hi Hamish,
Thanks for reply. With the above setup will there be any STP loop? The other interface between two F5s are:
  • f51 trunk port to f52 trunk port (lacp)
  • f51 data port( untagged vlan) to f52 data port (untagged vlan)
Will these 2 connections will bridge traffic?
Thanks!
The only time that the bigip will bridge traffic is if you tell it to. If the connections are configured as LACP on the bigip they’re a single logical link and will only actually come up if the other end is a single LACP endpoint as well. So no STP loop there.
H
Hi Hamish, the scenario above is, there is another cable connected between two f5 devices. In addtion to the trunk ports. Because they are wrongly patch. And the trunk port supposedly connected is connected to the switch access ports.
Thanks!
As Hamish said, the only time the F5 will send traffic across multiple links is when you tell it to.
For me that is most commonly performed using a trunk link on the f5 connected to a Cisco ether-channel at the switch (LACP). The other option that you can do to send traffic across multiple links and also multiple trunks is the VLAN Group.
In your case, if you have not configured a VLAN Group on any device then there should be no risk of looping. If your trunk/ether-channel configuration is setup correctly then that should function correctly also.
I always have a “private” connection between the HA pair of devices to use for things such as network failover and connection mirroring. This private link gets a VLAN assigned to it that is not present on the connection to the switch.
In short, as long as the same VLAN does not exist on the connection to the switch and the connection to the other F5 unit, you should not have issues. I recommend running two links to each f5 and switch as a trunk/ether-channel combination, and then run two links between the pair and set them up as a trunk, also. (We don’t run access port configurations anymore, they are too limiting)
Hi Josh,
Thanks for your comment and Hamish as well. So based on the attached diagram, if in case wrong cables are patched (as per scneario in diagram), there will not be any issue or STP looping but the end switch port will be shutdwon or will be in inconsistent error state because it is configured with etherchannel.
From the scenario, the cable for access ports supposedly connected to Data ports of F5 are wrongly connected to one of F5s Trunk interface that is configured as member of Trunk (F5 Term) or Etherchannel(Cisco Term) between F5 devices. And the cables for trunk ports are instead connected to Data ports between F5 device.
And also, what it the Switch access ports that are wrongly connected to F5 trunk ports are configured with portfast? Will it cause any loop?
As per previous question, portfast connected to F5 may cause loops but is it also applicable from scenario in the diagram? DevCentral - An F5 Technical Community
Thanks.
I’m not an expert on Cisco, but in my opinion, portfast has no business in the datacenter, and definitely not on a switch that would be connected to servers or other network devices. Portfast is meant for stuff like desktop PCs and other end user devices.
If the F5 ports are configured as trunk ports with a VLAN tagged and they end up connected to an access port on a switch, I’m fairly certain it would not pass traffic.
The private connection between your F5 units should never be configured to allow traffic to enter via the switch and then cross that link, so should not be able to create a loop. (ie: switch → f5 1 → f5 2 → switch, should never be possible unless you configure it to be so, and is a bad practice if you do configure it as such.) That connection should be setup to only allow each f5 to contact it’s peer.
The scenario you are describing would require mis-configuration of the F5, the switch, and the cabling, and is very remote.
Thanks for your comment Josh. So the given scenario should not have any issue or STP loop or will disrupt the existing network in case the cables are wrongly plugged as per scenario in the diagram above (except that the end switch port will go to inconsistent error state because the end F5 devices are configured with Trunk/Etherchannel using LACP mode). Currently, I don’t have the configuration information on the switch except that it is configured as an access port.
Thanks.
That’s correct. But doesn’t consider you creating a loop by connecting two switchports (on the cisco switches) directly together with portfast enabled :wink: H
Presumably the switchports to the bigip are cisco trunks… Portfast is an accessport thing. Trunk ports always do stp. H
Hi Hamish,
So if the F5 Trunk ports (Etherchannel) is connected to the cisco switch port configured with access and portfast enabled as per the scenario will not create any issue or STP loop (except the end switch port will be in disabled state? Since F5 is configured as trunk (LACP) and is not bridging STP.
F51 Trunk port1 (LACP active mode) → Cisco Switch Access port with portfast
F51 Trunk port2 → F52 Trunk port2
F51 dataport → F52 dataport
Thanks.
It shouldn’t do, because as said earlier 2 interfaces in a port-channel will never bridge. But I wouldn’t enable port fast on a link to a BigIP. Portfast should ONLY ever be used when connecting to SERVERS that are incapable of bridging (i.e. Only have 1 interface is a good start :slight_smile: )
NEVER connect a port fast interface to a switch device (And the BigIP should be considered a switch device as it will quite happily bridge interfaces if you tell it to).
H
Hi Hamish, thanks a lot for your comment.
