F5 Transceiver Wavelength
Is there a way to get transceiver wavelength data using an API?
I am specifically looking for a way to retrieve wavelength data from F5 transceivers via the iControl REST API (or any other suitable API).
thank you in advance :folded_hands:
you can try using icontrol api to get the transceiver media type which you can use to determine the optic wavelength
