F5 Sync Problem v. 11.4.1
Hi everyone
I’ve some problem about sync
I can’t sync F5 module APM v.11.4.1 HF2 which reside on differrent site
When I add peer apm, Log shown
“Can’t connect to CMI peer x.x.x.x, port:6699, Transport endpoint is not connected”
What does it mean ?
ps. Before add peer , we can iquery to each other. but after add peer we can’t iquery anymore.
Thank you in advance
Hi!
Have you verified that port 6699 is allowed on the self IPs used for synchronization?
/Patrik
before add peer , I can telnet port 4353 from local to peer after add peer, I cannot telnet port 4353 from local to peer It’s strange
port 6699 is used between local mcpd and tmm (i.e. not between unit in ha pair).
sol13946: Troubleshooting ConfigSync and device service clustering issues (11.x) (CMI communication channel)
I don’t know how to troubleshooting before add peer , I can telnet port 4353 from local to peer. But after add peer, I cannot telnet port 4353 from local to peer It’s strange Sync status is show disconnect because iquery communication can’t established . Question is why iquery is working properly but after add peer it’s struck. :frowning:
Many people affected by this kind issue and still don’t know the actual cause
After webex session with F5 support today
We still don’t know the root cause.
From my point of view,
It’s may be a bug because after add F5 peer unit, Local unit can’t establish iquery connection to peer unit , (peer unit also can’t connect to local unit)
What strange is , we type command “tcpdump -nni Internal tcp port 4353” and try to “telnet peer 4353”,… But no traffic show in tcpdump ??? It’s mean F5 didn’t even try to send packet from this port. But From “tmsh run /cm sniff-updates”, we can see daemon want to send packet to peer unit. :frowning:
So sync status still disconnect and we struck :frowning:
Just update to all of you
network (e.g. subnet) and route on both units are configured correctly, aren’t they?
Everything is correct, Before add peer Everything is fine , we can telnet port 4353 to unit 2 and what is necessary. But after add peer, We can’t telnet port 4353 to unit2 anymore (Then BIGIP always in disconnect sync state because it can’t establish iquery connection)
but we can telnet port 4353 to other F5 that is not their peer , :frowning: So strange
Have you been running tcpdumps in the firewall/routers on the way to the peer unit? I mean, if you can see the packets leaving the local interface there must be something stopping it on the way. Firewall? IPS? Bad routing configuration?
/Patrik
Tried to reload mcpd? 404 Page not found | BIG-IP Documentation
Try to do a tcpdump between the two interfaces without a port filter?
Can you post your config and a network topology?
/Patrik
My college has do something and we seem to passed this problem (I’ll ask him detail and share with all of you around next week)
But we face another problem
When we tried to sync >> It show sync failed and log show about “master decrypt fail during rekey”
So I want to rekey by “f5mku -r [keyofpeerunit]”
Problem is error occur >>> “master decrypt failed during rekey”
Anyone experience this problem?
Thank you
Hi Teepan,
After reading the above thread I m assuming that there are only two devices in the Sync-Failover group. Have you tried by resetting the device trust and removing the devices from Syn-failover group, delete the existing sync-failover group and start from scratch everything (Follow the right steps or the document).
I believe it should work.
Regards.
can you try to delete configuration on standby which requires passphrase (e.g. delete ltm virtual, delete ltm profile client-ssl, delete ltm profile server-ssl) then re-key (e.g. f5mku) and configsync?
