f5 snat list translation and issue with telnet and wget
hi all,
i’ve this situation:
server as01 → f5 → external system
- only the f5 has visibility of external system (10.193.91.198)
- f5 is the default gateway on internal vlan of server as01
- a snat translation list is made with the ip 10.193.91.198
from the f5 the external system is reachable:
[root@f5:Active] config tcptraceroute 10.193.91.198 -p 80
traceroute to 10.193.91.198 (10.193.91.198), 30 hops max, 40 byte packets
1 (10.193.37.1) 0.613 ms * (10.193.37.1) 0.992 ms
2 * * *
3 * * *
4 * * *
5 (10.193.91.198) 15.436 ms 15.296 ms 15.325 ms
[root@f5:Active] config telnet 10.193.91.198 80
Trying 10.193.91.198…
Connected to 10.193.91.198 (10.193.91.198).
Escape character is ‘^]’.
telnet> quit
but from the server as01 i’ve a strange issue:
- ping works
- tcptraceroute with specific port 80 works
- telnet (or wget) to specific port 80 doesn’t work
[root@SC-MUC-tgepreas01 ~] ping 10.193.91.198
PING 10.193.91.198 (10.193.91.198) 56(84) bytes of data.
64 bytes from 10.193.91.198: icmp_seq=1 ttl=255 time=0.205 ms
64 bytes from 10.193.91.198: icmp_seq=2 ttl=255 time=0.160 ms
64 bytes from 10.193.91.198: icmp_seq=3 ttl=255 time=0.210 ms
--- 10.193.91.198 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.160/0.191/0.210/0.027 ms
[root@SC-MUC-tgepreas01 ~] tcptraceroute 10.193.91.198 -p 80
1 sctgepreextservitds (10.193.91.198) 0.561 ms 0.542 ms 0.530 ms
[root@SC-MUC-tgepreas01 ~] telnet 10.193.91.198 80
telnet: connect to address 10.193.91.198: Connection refused
telnet: Unable to connect to remote host: Connection refused
any ideas?
can anyone help me please?
thanks in advice
I think that you should also create a network forwarding vs on the f5. all vlan should enabled for the server vlan and destination ip should set 0.0.0.0 and net mask 0.0.0.0 .
hi Rise,
thanks for ur support. with this virtual server (also configured to auto map the snat pool) all works.
thanks a lot
