As part of the MVC project, I need to implement SSO using F5 IdP (Identity Provider Initiated authentication). I have already got the F5 Idp Metadata XML file. Since I’m very much new to this SAML part, I don’t know what should be done with F5 Idp SAML metadata. I have gone through many sites but could not get right info. Kindly suggest any open source code (MVC) that completely implements.
Thanks in Advance.
Thanks & Regards, -Kalyan
