hi, i am new to F5 and trying to setup tings. i have configured reverse proxy setup for an application on F5. application is running on a backend server on port 7080. i have created 2 virtual servers http and https. has created an ssl profile and using that in the https Virtual server. trying ssl offloading as well.
Backend server is running the IIS application on port 7080. i have created the pool with node listening on port 7080.
i have only one node. F5 server is able to ping the backend server. but i don,t see any traffic going from f5 server to backend server when i try the URL. backend server is running in local nett have opened all the required ports in the firewall.
You have a HTTP and a HTTPS virtual server. Is there a HTTPS redirect iRule configured on the HTTP virtual server?
Is SNAT configured on the virtual server? A ping from the F5 uses the self IP of the F5 node as the source. If SNAT is configured, this SNAT address is used for connections to the backend server.
You say you cannot see traffic from the F5. How did you check this? With a tcpdump on your F5 node? Or do you check the logging of the internal firewall?
When you use the URL, do you see the correct virtual server being hit?
I would use tcpdump to check if you see traffic coming in on the correct virtual server on the inbound interface and do the same on the outbound interface.
