Hello Folks, I need to setup F5 redundancy for existing F5 appliance which is in production with two vcmp guest these guest are handling critical applications so we need to bring that in HA. Hence we already have procured the same hardware . so please help me on the below concerns. A- Shall we do the HA for vcmp hosts also or only for the vcmp guests respectively ? B- What config should be prepared in advance on the other standby appliance to sync the config with active appliance ? C- What config will be sync with the standby appliance (example certificate chain etc) from the active appliance ? D- Any other recommendation for successful HA setup.
When it comes to HA and vCMP, the vCMP hosts are configured as standalone devices. You only configure HA on the vCMP guests.
As to vCMP guest specific configuration, think of the following configuration items: hostname, mgmt address, vlans, non-floating self IP-addresses, route domains, trunk configuration.
Other configuration items like nodes, pools, virtual servers, static routes and floating IP adresses can by synchronized.
You can easily start building the new cluster member, add it as a trusted peer and to the device group. Try to sync to the group from the member that holds the complete configuration. If it fails to sync, it will give you a hint what could be missing on the new cluster member. Then you add the missing configuration item, and try to sync again.
