Guyz i need help. Im F5 ASM certified which is going to expire after a year. I would like to know if i take any other specialist exam like APM will it renew my ASM cert.
You have to pass both 301A and 301B to renew your f5-ASM or you can pass 303 and 304 exam.
Actually, each 30x exam is individual
When you say each exam is individual, you mean that i have to renew each specialist certificate separately.
Exactly. GTM exam is renewed with another GTM exam or 40x exam.
“Important: You are only required to retake the last exam in the highest certification achieved. However, if your certification expires completely, you must start the certification process over from the beginning.”
And these are the certifications available:
- F5-CA - F5 Certified BIG-IP Administrator
- F5-CTS - F5 Certified Technology Specialists
- F5-CSE - F5 Certified Solution Expert
REF - myF5
REF - Certification | F5
