I am investigating the possibility that, for incoming request traffic, the F5 can read from the TCP Option Header, and place the value in an HTTP header.
The use case for this is to support an application service that adds some needed information to the L4 header, via the TCP Option location. That information needs to find it’s way to the HTTP logs, so using the F5 to read from TCP/write to HTTP header seems logical, if it’s possible to do.
Thanks much- unclear to me that payload and collect will go up into the TCP header to capture the data, seems from the docs that it’s for the payload only. Did I miss something?
I think Deb previously mentioned a request for enhancement to be able to read the TCP headers from an iRule. You might try opening a case with F5 Support to check the status of the request and add your case to the RFE.
