F5 rate limiting with Irule
Hello,
I need to rate limit 2req/s on some specific url with irule. my F5 is behind a proxy, so i need to get client ip address with x-forwarded-for. can you share with me some irule?
Best regards
Hello @AldoSergio
you could try this
when HTTP_REQUEST
    set xff [HTTP::header "X-Forwarded-For"]
    if { $xff ne "" }
        set client_ip [lindex [split $xff ","] 0]
        set client_ip [string trim $client_ip]
	else
        set client_ip [IP::client_addr]
    if { [HTTP::uri] starts_with "/your/protected/path" }
        set key "ratelimit_${client_ip}"
        set rate_limit 2
        set window 1
        set req_count [table lookup -notouch $key]
        if { $req_count eq "" }
            table set $key 1 $window $window
		elseif { $req_count < $rate_limit }
            table incr -notouch $key
		else
            HTTP::respond 429 content {
                <html><body><h1>429 Too Many Requests</h1>
                <p>Rate limit exceeded. Please slow down.</p></body></html>
            } "Content-Type" "text/html" \
              "Retry-After" "1"
            return
