F5 provisioning
Just putting my lab together and getting this message when I try adding LTM and ASM and the following error message comes up …
01071008:3:Provisioning failed with error 1 - Disk limit exceeded. 20338MB are required to provision these modules,but only 30MB are available …
I have 93GB of space allocated for the VM and memory of 8.5GB .
Did you try adding the extra space it was failing for? Look at your VM and see if you have reclaimable space as well.
Yes. it was 60 GB and increased it to 93 GB .. Would increasing it more make a difference
Yes. I’m looking at my VM and I used 100GB and I have no issues running LTM and ASM. Try increasing it to 100GB and let me know the outcome.
I have increased to 130 GB and it is still complaining
The VM should have 2 partitions. What are the sizes of each?
[root@waf:Active:Standalone] config # df -h
Filesystem                            Size Used Avail Use% Mounted on
/dev/mapper/vg--db--vda-set.1.root    419M  77M 316M 20% /
devtmpfs                              4.3G 4.0K 4.3G  1% /dev
tmpfs                                 4.3G 2.3M 4.3G  1% /dev/shm
tmpfs                                 4.3G 2.3M 4.3G  1% /run
tmpfs                                 4.3G    0 4.3G  0% /sys/fs/cgroup
/dev/mapper/vg--db--vda-set.1._usr    5.0G 4.0G 738M 85% /usr
/dev/mapper/vg--db--vda-dat.share     477M 100M 348M 23% /shared
none                                  4.3G  45M 4.3G  2% /shared/rrd.1.2
/dev/mapper/vg--db--vda-dat.appdata    31M 4.5M  25M 16% /appdata
/dev/mapper/vg--db--vda-set.1._config 469M  15M 426M  4% /config
/dev/mapper/vg--db--vda-set.1._var    922M 355M 504M 42% /var
prompt                                4.0M  28K 4.0M  1% /var/prompt
none                                  4.3G  17M 4.3G  1% /var/tmstat
/dev/mapper/vg--db--vda-dat.log       477M  62M 386M 14% /var/log
none                                  4.3G    0 4.3G  0% /var/loipc
tmpfs                                 878M    0 878M  0% /run/user/91
tmpfs                                 878M    0 878M  0% /run/user/0
Go into the settings of VMWare Player (I presume that’s what you’re using) and review both partitions. I currently have the first partition at 82GB and the other at 20GB. ASM requires 20GB to run.
I am using Vmware esxi 6.5
Would this article help me : myF5
I have tried resizing this by using the command: modify /sys disk logical-disk <storage name> vg-reserved <new size> but nothing is working …
F5 uses LVM, so “df -h” is not the command you are looking for.
Try to check the free space using
# vgs
If you need more space you should increase the size of the disk in the hypervisor and reboot the box.
Removing some installation old volumes is also a good point to free space.
If you need to increase the space of an specific partition, you should resize it using this procedure
KR,
Dario.
We didn’t have enough space to provision the ASM and AVR modules on our F5 (BIG-IP v13.1.1.4) and increasing the partition /appdata with the following command solved it:
“tmsh modify /sys disk directory /appdata new-size <new-size>” (see the KB Extending disk space on BIG-IP VE: myF5).
