Hello,
I noticed that if I use the latest F5 plugin with Wireshark 1.12.x the decrypted packets are not being displayed. It works fine with 1.10.x or 1.11.x.
The SSL debug from Wireshark shows that the packet is being decrypted in all versions I tested. The problem with 1.12.x is that you will still see the TLS packet instead of for example the HTTP GET request.
I followed sol10209 to generate the pms file.
I tested with Wireshark Portable and an installed version of Wireshark 32-bit.
I compiled my own plugin and also tested the plugin from here DevCentral - An F5 Technical Community
OS: Windows 7 Enterprise 64-bit.
Has anyone else experienced the same behaviour?
*.x means I tested all subversions
Thank you.
Roland
I would suggest running wireshark natively 64bit on your 64bit OS. I’ve had no issues running the latest 64bit wireshark(1.12.3) on Windows 8.1 with the latest 64bit dll.
It works with the 64bit, but I am avoiding it because it has more bugs than the 32bit version. For the moment I will use the F5 plugin with Wireshark Portable 1.10.2. Thank you for the answer.
