In a webkit:
content disposition header, name=“file” ; filename=“EXAMPLE DOCUMENT 2024.txt”
Content-type: text/plain
Document data example system (
The issue is that there is already a parameter built at the URI for file as an upload, set to block executables. Yet, it seems that the F5 continues to scan the document and it is not picking up the built parameter. Is it doing this by design? Since F5 is able to parse text? This seems to happen on uploads whose content types are text and xml.
