I am new to F5. We are going to implement the reverse proxy,ssl offload, WAF, Load balancing, HTTP2(compress and store the local traffic as cache).
In this i have created the no and pool menbers. Since we are using the VM-Instances, we have place some servers in A-A & A-P.
While creating the virtual server, we are getting the following error.
Kindly advice us to create the above.
Please configure as mentioned below
Source address: 0.0.0.0/0 destination address:172.28.7.101
Thanks Raghavendra. now the virtual server created.
But 172.28.7.101 is the F5 internal N/W segment ip address. we are mapping this ip to selected pool members(virtual server). whether this is correct.
yeah, what will be your pool member IP’s.
Virtual server IP is 172.28.7.101
pool menbers NW are 172.28.3.0, 172.28.4.0, 172.28.5.0
Also the servers will communicate in both http and https. so whether we need to create two virtual servers. one virtual server for http and other for virtual server https.
You need to create two one is for http and other one is for https.
If you are redirecting traffic from http to https. Assign default http_to_https iRule to http virtual server and assign pool to https virtual server.
Thanks for your advice… i am creating the same..
