F5 LTM Virtual Statistics Timeframe
Hey, does anyone know how I can figure out the actual timeframe for the LTM Virtual statistics records?
For example, in the picture above, how long back does it check the “Total Requests”?
Hi Wyko,
Stats are stored in memory, and reset on reboot. The displayed value is the total value after the last reboot. Unable to filter by a specific time range. AVR module may be helpful.
Thanks for the link.
Hi  @422183   - I’m going to mark the reply from  @Enes_Afsin_Al  as an Accepted Solution so anyone searching for the answer in the future will easily see it in the results. Let me know if you are still experiencing the issue!
thanks for info
