F5 LTM TMOS - UDP Monitor V13.0.0 - Send Packets Feature? Number of UDP Packet’s Sent per Probe
Hi All
F5 LTM V13.0.0
For UDP monitor’s:
There does not seem to be a way to configure the amount of UDP packets that are sent within each probe per interval? This use to be possible within V9.3 looking at the old configuration guides with a feature called “Send Packets”
I checked an interim between the two of V11.2 which also does not seem to have the feature:
Do you know if this is possible? Apologies if I am missing something obvious, I have tried configuring this by creating or modifying existing UDP monitors either by TMSH or the TMOS GUI with no luck. I also attempted to configure this in tandem with an ICMP monitor as per the notes on V9.
This is not specific for any UDP service.
Thanks!
