F5 LTM off path design (with SNAT) and client IP logging
Hi Experts
I have one deployment for F5 LTM 6900. We want to load balance below applications on different servers.
  1. Exchange (OWA, MAPI, RPC OVER HTTP, OUTLOOK ANY WHERE)
  2. VDI (VIRTUAL DESKTOP INFRASTRUCTURE)
  3. LDAP
  4. SMTP GATEWAYS (INCOMING AND OUTGOING)
  5. WEBDEV (FILE SHARING OVER HTTP)
  6. COUPLE OF WEB APPLICATION (IIS, APACHE)
We do not want servers gateway to be F5. So we need to use SNAT on F5 (off path design). The problem is that how to get the client IP logs on application. For HTTP, I know we can use X-FORWARDER but what about other applications like SMTP Gateways, some TCP applications. Is there any IRULE for this OR any other method to used.
Also is there any harm if I make servers gateway F5? I believe this is not recommended
Looking forward for the reply
We have a similar situation where all traffic to nodes is SNAT’ed, mostly AutoMap, but some non-HTTP nodes need to log the connecting client’s IP. We use a simple iRule to log the connection:
when SERVER_CONNECTED {
HSL::send $hsl “<190> CONNECT: client [IP::client_addr]:[TCP::client_port] vip [clientside {IP::local_addr}]:[clientside {TCP::local_port}] node [IP::server_addr]:[TCP::server_port]”
Can’t you just create static routes on the servers for the client source IP ranges and point those at the F5, leaving the default and anything else pointing wherever it does now. It’s a much simpler solution.
Hi
Thanks for the reply. But could you please explain this IRULE? Actually I need to have client IP on APPLICATION ITSELF
I’m afraid the iRule won’t help you in that way. The rule simply documents the connection so that later, say for forensics or connection troubleshooting, you need to correlate the connecting client’s IP with the SNAT used (which would have a corresponding IP and ephemeral port in some log generated by your applications). Since your applications see the source IP as the SNAT you’d have to perform any necessary access control on the F5 (data groups, etc). I like Steve’s idea of simplicity but I don’t have control over the servers our F5’s steer traffic toward.
Thanks for the feedback
