F5 ltm http monitor
hi Guys , I have created a http monitor to get a file GET /live.html\r\n this send a string Live . When I activate this to the pool i get no response. But when I change to default https monitoring , I can see in IIS logs some traffic and responses 200 back. Not sure why when I Get live.html file from the web server do not show any log information. I dont see any responses or logs on the web server. How can I trouble shoot this. using LTM 13.0 version. Any pointer is appreciated.
Hello SP,
https = 443 http = 80
Are you sure the right Port is open? You wrote two different Protocols in your Question.
" I have created a http Monitor" “But when I change to default https Monitoring”
Greetings, Maximilian Martin
Thanks Martin, the ports were blocked on the server. Regards Sunil
You are welcome :slight_smile:
