I have configured F5 in active-standby mode and they are running 12.1.2 version, I have configured Fail-over with VLAN interface and Management interface, also i have put hardware failover cable between two unit (RJ45 crossover cable connected to Failover Port).
Now i want to check whether my
Failover
hardware port is in-use or not, following command output showing.
root@(F5-1-mgmt)(cfg-sync In Sync)(Active)(/Common)(tmos) show sys failover cable
cable state 0
for testing i have unplugged cable and check status still its showing
cable state 0
?? is that correct behavior?
also what if my VLAN trunk failed in that case how does failover will work ?
