I’ve used the same HTTP profile across several Virtual Servers (effectively the standard HTTP-wan-optimized-compression-caching). A couple of Virtual Servers use the same URIs, but obviously these are different URLs. They also use common members (same IP and Port).
We seem to be having issues with cached content, old content is being delivered to the client. I have tested by removing the HTTP profile, this resolves the issue.
I would like to understand how is the cache maintained? Is there a separate cache per Virtual Server, per http Profile, or is it just based upon the URI or URL?
Also is there any chance a cached entry could cross Virtual Servers in the scenario mentioned above?
