F5 Ltm Backup Script
Hello Experts,
Reference:- DevCentral I have taken reference from above URL and modified and have used below script to take backup of F5 , however the backup is not working/coming to FTP. I am not much of a script guy , so can anyone suggest me, what i am doing wrong in here. Also i want to know at which time this script will execute. Much appreciated.
!/bin/sh -x Name: backup_cron_scriptv10.sh BIG-IP Backup Script This script automates LTM v10 Backups and saves the files with hostname and date off to an FTP server version 1.0 Author: Bhattman Original Date: 01/07/10 Backup your config in ucs
b config save /var/tmp/BIG-IP_backup export a=
date +"%y%m%d"
export aa=$HOSTNAME.$a.ucs export b=/var/tmp/$aa mv /var/tmp/BIG-IP_backup.ucs $b Backup the SSL Certs
tar -cf /var/tmp/certs.tar /config/ssl export ff=$HOSTNAME.$a.certs.tar export f=/var/tmp/$ff mv /var/tmp/certs.tar $f
copy your crontab information - it can be other files as well
export c=$HOSTNAME.$a.crontab export cc=/var/tmp/$c cp /etc/crontab $cc
export MName=<192.168.1.100/F5> export Log=/var/tmp/log.bigip
ftp username and password
export UserName=admin export UserPassword=admin
export Machine1f2=$aa export Machine1f3=$c export Machine1f4=$ff
ftp command that sends the files over to ftp server
ftp -nvd ${MName} <<-END 1>&2 > ${Log} user ${UserName} ${UserPassword} bin put ${b} ${Machine1f2} put ${cc} ${Machine1f3} put ${f} ${Machine1f4} quit END
removes the copied files after push
rm -f ${b} rm -f ${cc} rm -f ${f} RTN_CODE=$?
exit $RTN_CODE
I understood your problem and your BIG-IP version is in 10.x correct? The problem may lie in “export MName”. Can you post again the script in code format? To do this, each line needs to start with four blank spaces. See in “how to format”. tks
Yes version is 10.x. I intentionally put “export MName <192.168.1.100/F5> because i wanted all my FTP related files to go under F5 folder only. However i have tried with “export MName <192.168.1.100> it didn’t work either. Other steps that i did after creating script. Created a file called backup_cron_scriptv10.sh in /etc/cron.daily, and executed by chmod 775 “backup_cron_scriptv10.sh” Below is the script. b config save /var/tmp/BIG-IP_backup export a=`date +”%y%m%d”` export aa=$HOSTNAME.$a.ucs export b=/var/tmp/$aa mv /var/tmp/BIG-IP_backup.ucs $b tar -cf /var/tmp/certs.tar /config/ssl export ff=$HOSTNAME.$a.certs.tar export f=/var/tmp/$ff mv /var/tmp/certs.tar $f export c=$HOSTNAME.$a.crontab export cc=/var/tmp/$c cp /etc/crontab $cc export MName=<192.168.1.100/F5> export Log=/var/tmp/log.bigip export UserName=admin export UserPassword=admin export Machine1f2=$aa export Machine1f3=$c export Machine1f4=$ff ftp -nvd ${MName} <<-END 1>&2 > ${Log} user ${UserName} ${UserPassword} bin put ${b} ${Machine1f2} put ${cc} ${Machine1f3} put ${f} ${Machine1f4} quit END rm -f ${b} rm -f ${cc} rm -f ${f} RTN_CODE=$? exit $RTN_CODE
Hi, You can test this version now? at the moment I am unable. I added a field “MDir” to define your target directory. If that does not work let me fix that for you. Tks
!/bin/sh -x
 version 1.0
 Author: Bhattman
export a=`date +"%y%m%d"`
cp /etc/crontab $cc
export MName=192.168.1.100
export MDir=/F5/
bin
put ${b} ${MDir}${Machine1f2}
put ${cc} ${MDir}${Machine1f3}
put ${f} ${MDir}${Machine1f4}
quit
END
rm -f ${b}
rm -f ${cc}
rm -f ${f}
RTN_CODE=$?
exit $RTN_CODE
Dear all,
How can I have the same script for SCP server instead FTP? A little urgent, if someone can look into this.
Cheers!
hi,
how can we use SCP ?
This is how I’ve done it via SFTP and key authentication. You need to first create a dsa key to use for authentication to your SCP/SFTP server. Then put the script in a file named /config/backup and create a chron job using this,
chmod +x /config/backup; ln -s /config/backup /etc/cron.daily/backup
!/bin/bash
 Set variables for UCS file name
dt=`date +%Y%m%d`
hostname=`uname -n |cut -d. -f1`
DDIR=/var/tmp
SFTPhost=
 Delete old ucs file created by this script
rm $DDIR/$hostname*.ucs
 Send syslog message to log servers
logger -p local0.info -t BIGIP configuration backup started.
 Commit configuration from memory to files
cd /config
tmsh save /sys config
 Create configuraiton archive
tmsh save /sys ucs $DDIR/$hostname-$dt.ucs
 Send to admin server via SFTP
cd $DDIR
sftp -oIdentityFile=/config/sftp_dsa $hostname@$SFTPhost<< EOF
cd $hostname
put $hostname-$dt.ucs
quit
EOF
logger -p local0.info -t BIGIP configuration backup completed.
