hi Michael, good point.
by the way, just curious when a number of active pool member in priority group 2 is less than 4, will priority group 1 bring only some of its pool member (not all the member)?
this is my test. could you please advise if i missed anything?
[root@ve1023:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.79:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve1023:Active] config b pool foo list
pool foo {
min active members 2
monitor all http
members {
200.200.200.101:80 {
priority 2
200.200.200.102:80 {
priority 2
200.200.200.111:80 {
priority 1
200.200.200.112:80 {
priority 1
[root@ve1023:Active] config b pool foo|grep -i pool\ member
+-> POOL MEMBER foo/200.200.200.101:80 active,up
+-> POOL MEMBER foo/200.200.200.102:80 active,up
+-> POOL MEMBER foo/200.200.200.111:80 active,up
+-> POOL MEMBER foo/200.200.200.112:80 active,up
[root@ve1023:Active] config ab -c1 -n100 http://172.28.19.79/
POOL foo LB METHOD round robin MIN/CUR ACTIVE MEMBERS 2/4
| (cur, max, limit, tot) = (0, 2, 0, 100)
| (pkts,bits) in = (500, 287200), out = (500, 597200)
| | session enabled priority 2 ratio 1
| | (cur, max, limit, tot) = (0, 1, 0, 50)
| | (pkts,bits) in = (250, 143600), out = (250, 366000)
| | requests (total) = 50
| | (pkts,bits) in = (250, 143600), out = (250, 231200)
| | session enabled priority 1 ratio 1
| | (cur, max, limit, tot) = (0, 0, 0, 0)
| | (pkts,bits) in = (0, 0), out = (0, 0)
| | requests (total) = 0
+-> POOL MEMBER foo/200.200.200.101:80 inactive,down
POOL foo LB METHOD round robin MIN/CUR ACTIVE MEMBERS 2/3
| (cur, max, limit, tot) = (0, 3, 0, 100)
| (pkts,bits) in = (500, 287200), out = (500, 551368)
| | (cur, max, limit, tot) = (0, 1, 0, 33)
| | (pkts,bits) in = (165, 94776), out = (165, 152592)
| | requests (total) = 33
| | (cur, max, limit, tot) = (0, 1, 0, 34)
| | (pkts,bits) in = (170, 97648), out = (170, 157216)
| | requests (total) = 34
| (pkts,bits) in = (165, 94776), out = (165, 241560)
thanks!
