Hi guys, anyone facing load balancer get stuck in loading state before? I try to reboot and console into the device but unfortunately no works.The error code is 06b. Thank you.
you have 2 alternatives:
- First one (more simple):
Connect in Serial and during the boot try to change the boot volume (don’t use default). of course if you have several volumes
- Second one: create a bootable key --> Normally F5 provides you one with the equipment:
You can create this bootable key on the second equipment (simple and quick). then re-install you equipment.
If you need assistance don’t hesitate.
Regards
