F5 Lab edition: shell prompts shows "ModuleNotLicensed" ?
Hi out there at last I got a lab licese for my VE on my labtop - but the prompt tells me “ModuleNotLicensed” - I expect that this is because of the APM module which as far as I can see is running without a license and then gives me a reduced 10 user license - is this correct or could there have occured an error when I licensed the modules - here is output from tmsh:
root@(bigip1)(cfg-sync Standalone)(ModuleNotLicensed:Active)(/Common)(tmos.sys) show license
Sys::License Licensed Version 11.3.0 Registration key VJRJA-YUMXR-DIOSD-TLQMK-IWBDWJK Licensed On 2014/01/23 Service Check Date 2014/01/22 Platform ID Z100
Active Modules BIG-IP, LAB (LTM,APM,ASM,AM, GTM), VE (CMDFNOC-EVVGBQT) IPV6 Gateway Rate Shaping Ram Cache 50 MBPS COMPRESSION SSL, 500 TPS Per Core Client Authentication ASM, VE AFM, VE WOM, VE DNS Services WBA, VE PSM, VE Acceleration Manager, VE DNSSEC Anti-Virus Checks Base Endpoint Security Checks Firewall Checks Network Access Secure Virtual Keyboard APM, Web Application Machine Certificate Checks Protected Workspace Max Compression, VE Remote Desktop App Tunnel SSL, Max TPS, VE Routing Bundle, VE DNS Rate Fallback, 50 GTM Rate Fallback, 8 DNS Licensed Objects, 0 GTM Rate, 8 DNS Rate Limit, 50 QPS GTM Licensed Objects, 0 DNS Rate Fallback, Unlimited DNS Licensed Objects, Unlimited DNS Rate Limit, Unlimited QPS DNSSEC (ATOIHVR-QTPDMEK) GTM, VE (TNGROJI-DFCIGMN) IPV6 Gateway Ram Cache STP DNS Express Routing Bundle, VE GTM Licensed Objects, Unlimited DNS Rate Fallback, Unlimited DNS Licensed Objects, Unlimited GTM Rate Fallback, (UNLIMITED) DNS Rate Limit, Unlimited QPS GTM Rate, Unlimited
best regards /ti
Turn off APM, see whether it disappears. It makes sense for it to be this though - I have seen this message myself.
Hi Pete Could be worth to try - but got a note back from the F5 Guys where we bought the license that “this was the cause”
best regards /ti
ps - tried it and yes - the notice did disappear - and also the apm module…
you use APM in limited mode, that causes it, doesnt hurt the system further.
