F5 kubernetes f5 controller failing to compose 'poolMemberAddrs' and failing to generate F5 objects
Hi - I set this up: F5 Kubernetes BIG-IP Controller — F5 Kubernetes BIG-IP Controller v1.0 and getting errors after uploading my configmap and an applicable service:
2017/04/28 23:43:30 [INFO] File “/app/python/_f5.py”, line 393, in _create_ltm_config_kubernetes 2017/04/28 23:43:30 [INFO] for node in backend[‘poolMemberAddrs’]: 2017/04/28 23:43:30 [INFO] TypeError: ‘NoneType’ object is not iterable
The config file generated by /app/bin/k8s-bigip-ctlr does not populate “poolMemberAddrs” so the python f5 handler /app/python/bigipconfigdriver.py is crashing since it cannot figure out the nodeport targets:
/app  cat /tmp/k8s-bigip-ctlr.config281602422/config.json
{“bigip”:{“username”:“xxxxxxxxx”,“password”:“yyyyyyyy”,“url”:“;:[“k8s”]},“global”:{“log-level”:“INFO”,“verify-interval”:30},“services”:[{“virtualServer”:{“backend”:{“serviceName”:“av-service”,“servicePort”:30000,“poolMemberPort”:0,“poolMemberAddrs”:null},“frontend”:{“virtualServerName”:“default_av-service”,“partition”:“k8s”,“balance”:“round-robin”,“mode”:“http”,“virtualAddress”:{“bindAddr”:“1.2.3.4”,“port”:80},“iappPoolMemberTable”:{“name”:”",“columns”:null}}}}]}/app
I ran out of anything helpful with debug statements or documentation about the closed source go binary…
io:$ kubectl get services/av-service -o wide
NAME         CLUSTER-IP      EXTERNAL-IP   PORT(S)        AGE       SELECTOR
av-service   10.25.104.158          80:30000/TCP   2h        app=av
io:$ kubectl get nodes -o jsonpath='{.items[*].status.addresses[?(@.type=="InternalIP")].address}'
10.25.82.193 10.25.82.65 10.25.83.54
Is this the right place to ask about what possible reasons the controller is crashing here?
You’re configmap looks ok, but can you post the output of that file you applied to your cluster?
kubectl get configmap ${F5_CONFIGMAP} -o yaml
Also, what version of Kubernetes are you running? v1.6?
Hello everyone,
i was able to make work of creating VS on F5 with Kubernetes 1.6.4 by setting permissive RBAC settings using this command.
kubectl create clusterrolebinding add-on-cluster-admin --clusterrole=cluster-admin --serviceaccount=kube-system:default
It can be seen at the end of this document
Edit: It is possible that it is not a complete fix. I saw some messages in syslog about the pool ip addresses. Now I see a virtual server in F5, but still no pool members. I’m using same ConfigMap that is in this thread.
Edit2: The RBAC setting did not help. If anyone has any suggestions, i’m willing to test them.
The F5 container connector doesn’t support v1.6 just yet. Work is happening now to add support for this. Mainly because v1.6.x requires RBAC. So the k8s-bigip-ctlr needs to have a cluster role in order to access the API server.
I can update you as the dev team makes progress on this.
