Hi All,
I have a issue about my F5 LTM 6400, i check the health of f5 machine using tmstat and found memory almost full, when the memory almost same with memory allocation, the application behind f5 will be error and running well when f5 reboot. i think this because the memory issue, any one have a experience like this? please kindly help me to solve my issue about memory.
Hi Jellf,
That sounds like a memory leak. I’d suggest opening a case with F5 Support to get help troubleshooting this. Chances are, it’s a known issue which has been fixed in a more current release.
Aaron
Thanks for your suggestion, i try find a log for this, and found this log :
<13> May 13 20:52:27 local/lb1 notice Set initial cmp state to 0x1.
<13> May 13 20:52:27 local/lb1 notice Scheduler: 10%: 3% yield [ 0% lic, 10% db, 0% po, 3% tcl] after licensing
<13> May 13 20:52:28 local/lb1 notice cn0: Cavium NITROX (8 units); in 64 bit, 100 MHz PCI/X slot.
<13> May 13 20:52:28 local/lb1 notice bge0: reset successful
<13> May 13 20:52:28 local/lb1 notice bge0: chip initialization successful (chipid 0x21000000)
<13> May 13 20:52:28 local/lb1 notice auto, 10baseT-FDX, 10baseT, 100baseTX-FDX, 100baseTX, 1000baseTX-FDX, 1000baseTX
<13> May 13 20:52:28 local/lb1 notice bcm570x0: 0.1 pci 2:9.1 dev_index 0 PVA primary
<13> May 13 20:52:28 local/lb1 notice bge0: Ethernet address: 00:01:d7:73:66:05
<13> May 13 20:52:28 local/lb1 notice bge0 Setting promiscuous mode
<13> May 13 20:52:29 local/lb1 notice bge0: fast path enabled.
This Log mean f5 already restart a network device with Mac Address 00:01:d7:73:66:05.?
this log from /var/log/tmm
