F5 irule - Universal persistence
Is there any F5 irule command to parse some data from HTTP response?. For example, I am using below command to read “context ID” from http request, similarly is there any command we can use for parsing http response?
when HTTP_REQUEST { set cid [findstr [HTTP::uri] “contextId” 10 “&”]
Thanks, Akhilesh
Sounds like you’re looking for HTTP::payload
yes, you can use the same findstr command in HTTP_RESPONSE event (provided the data in you need to parse is in response headers and not in the content)
